1997 transmission in 1998 will it work ?
Old Jul 30, 2018 | 06:19 PM
Big'n's Avatar
Big'n is on a distinguished road
Default 1997 transmission in 1998 will it work ?
i have a 1998 gmc jimmy 4.3 vortec 2 wheel drive an the trans has gone out. I have a 4l60-e trans out of a 1997 chevy s-10 same motor as Jimmy will the 97 work in the 98 jimmy. I've been told yes an no.
Old Jul 30, 2018 | 07:49 PM
Transman304's Avatar
As long as it is a 2wd also so a direct bolt in. Also both need to be a 2 piece case design.
Old Aug 1, 2018 | 07:42 PM
Big'n's Avatar
Ok guys so might not need a new transmission. It skips 1st starts off in second wont go into over drive. Throws a shift solenoid code. Clear the code starts off in first an goes all the way to over drive. Stop at a red light an code pops up an wont go to 1st or OD again clear code an it shifts perfect. Any ideas ? Ready....Set.....Go!! Lol
Old Aug 2, 2018 | 10:07 AM
What code number are you getting?
Old Aug 2, 2018 | 05:51 PM
Big'n's Avatar
po758
Old Aug 3, 2018 | 09:44 AM
Might start by changing out the shift solenoids. Just be careful not to break them when removing or installing the pan. Easily broken. May want to also change out the 3-2 coast down solenoid while pan is dropped. It is a known failure item.
Old Aug 3, 2018 | 04:59 PM
Big'n's Avatar
Ok so we swapped entire transmission. Did not fix the problem. I can still clear code an it shifts perfect until I stop an then have to clear code again. Turns out it's the ECM no problem got one from LKQ 20 bucks WOOHOO !!!!! Wrong !!!! No WOOHOO put it in an truck wouldn't start. Not sure why it came off of a 1998 s10 blazer same motor he'll pretty much same truck I have mines just a GMC. Old ECM is fried it smells like a burnt amplifier. Not sure why the other won't work. I'm no mechanic I'm a stereo guy lol
Old Aug 3, 2018 | 06:00 PM
Big'n's Avatar
Rumor is I can get a ECM set to my VIN number for 80 bucks is that what I should do or do you have another idea ?
Old Aug 3, 2018 | 08:53 PM
chevyriders's Avatar
You need to have the ecm reflashed to your vin
Old Aug 3, 2018 | 09:28 PM
Big'n's Avatar
Dealer wants 190 bucks to flash it. That's crazy. A company called FS1 inc has one I can get programmed to my vin for 80 bucks plug an play so they say. Is there any other way like a secret code or something. Like Nintendo Up Up Down Down left right left lol
