1998 Blazer still ticks....
Ok so here we go again. My 1998 Blazer 4.3 4X4 is still ticking. I checked the valve adjustment on the passenger side, since that's where the noise seemed to be coming from, and the valves were all adjusted to spec. After doing some research, I found that it could have been the EGR valve needing a cleaning. I went ahead and replaced that and it still ticks. I have no idea what to try next.
Is it a constant ticking or random? Does it speed up when you rev the engine? If it's constant at idle, and speeds up when you rev it, you may have a dead lifter. Sometimes you can throw some seafoam or another oil additive and get it to pump up, other times you have to replace them. It could also be one of the accessories like the water pump, alternator, ps pump, or AC. Get a stethoscope or a long 3/8"s extension and put your ear up to it and touch different spots around the engine, if it gets louder, you're getting closer.
I forgot to mention it starts ticking when it starts to warm up. Its fine the first few minutes of being started up. I haven't thought to check the pcv valve. I'll probably wind up replacing it lol.
Ok, so I replaced the PCV valve, and the ticking still hasnt gone away. I'm gonna try the seafoam and see if that does the trick. My only question about the seafoam is do you have to add it every oil change, or can you do it with one oil change and cure the problem? Thanks.
It's not the valves! It's an injector. I used a stethoscope and checked all the valves. It didnt have any noise from the valves, so when I put it on the intake I heard it clear as day from the passenger side. So I guess all I gotta do is try sea foam in the gas tank and throttle body and see if that cleans it up and frees it!
I never heard of an injector ticking.You have poppet injectors inside your planem they are not mechanical.Maybe the noise you heard is a dead lifter.If it is.Do an oil change and subsistute a quart of oil with marvel mystery oil.It will pump it up and silence the ticking.
