1998 Bravada engine interchange?
Old Dec 23, 2010 | 06:53 PM
thereverendbill's Avatar
thereverendbill is on a distinguished road
Default 1998 Bravada engine interchange?
i have a 1998 Olds Bravada with the 4.3 that overheated, so i know at the very least the head gaskets are shot. a friend of mine told me that he has a 91 S-10 blazer with the 4.3 that i could have to get my olds back on the road. My big question is do the engines interchange? I would be using my intake because shortly before the "cooking" I put a new fuel spider in
Old Dec 23, 2010 | 06:57 PM
Short answer is no. You need a 96+ engine for your truck.
Old Dec 24, 2010 | 01:57 AM
TZFBird's Avatar
TZFBird is on a distinguished road
What happens when it overheats? P.O. has lots of receipts in the glove box from shops because of overheating or something. I flushed system and replaced thermostat and have not had a problem. I also removed the plastic air diverters in the front as well though.
Old Dec 24, 2010 | 08:10 AM
What happens when an engine overheats depends on how hot things were. If the vehicle is stopped quickly, no real damage will occur. But if it is driven while the coolant is boiling off, the heads and sometimes block can be permanently damaged.
metzkerdavid
Dec 31, 2010 12:21 PM
Huntingman2706217
Sep 21, 2010 08:01 PM
thereverendbill
Jun 19, 2010 10:12 PM
kjmitchell
Jun 18, 2010 12:39 AM
g33knik
Mar 23, 2009 03:31 PM
