1999 Blazer Engine Problems Beileve Its The Fuel Filter Or Pump
Old Apr 9, 2012 | 08:37 PM
50lb_cat's Avatar
Yes, change the filter then re-test. If that doesn't fix it and you replaced the regulator, then the next thing on the list is a leaking injector.
Old Apr 9, 2012 | 09:03 PM
pettyfog's Avatar
Originally Posted by sosayoola
I check the gas pressure with the key on and it went up to 55 then decreases all the way to 0 it stays at 55 for about 3 sec's then it goes down to 0 but I changed the fuel pressure regulator and that didn't work what else so I do? The fuel filter?
I assume what you mean is it goes to 55 for 2-3 secs and soon as the fuel pump turns off down to 0 within a few seconds.
With that upper manifold off, turn key on and look for any signs of fuel leakage. Dont forget, if the connection on the gauge leaks at all that will fake that leakdown problem.
Hmmm seems to me I said 'change the fuel filter first', several times. Now you want me to say it again? It's too late.. you changed the pressure regulator first.
Now you need to test the pump for deadhead pressure and leakdown at the filter connection.
Go here and scroll to bottom for directions:
https://blazerforum.com/forum/tech-a...agnosis-23038/
Old May 14, 2014 | 10:19 AM
James Pilgram's Avatar
James Pilgram is on a distinguished road
ok im new here so i really dont know where to ask questions lol..but i have a 1999 chevy blazer that started bogging out when i press the gas..Ive heard maybe it could be the fuel filter can anyone help me with this please?
Ashley Davis
Apr 22, 2015 11:44 PM
95jblaze
Aug 27, 2011 03:46 PM
matt92
May 1, 2011 04:39 PM
sbrookover
13
Dec 29, 2009 08:43 AM
RCars2
Aug 4, 2007 11:29 PM
