2.8 won't start
Old May 4, 2010 | 12:38 PM
hairymonster1's Avatar
hairymonster1 is on a distinguished road
Question 2.8 won't start
1991 2.8 with around 134,000 miles. it was running fine I stopped at a four way and it died. it's getting fuel & spark. sometimes if I hold the gas to the floor it will run I'd say well below 500rpm's for about 1 minute or till I let off the gas. I get a code for map sensor but the one on it checks out good and I replaced it with a known good one and I still get the map code. It does need a new idle air control. fuel pump and relays replaced less than two months ago. any idea's what I should check next??
Old May 4, 2010 | 01:28 PM
Will it start with some starter fluid? Have you tested spark timing with a timing light?
Old May 4, 2010 | 04:52 PM
I shot some starting fluid in it and seemed like it flooded it. after the sun goes down a little I'm going to try the timing light.
Old May 4, 2010 | 04:57 PM
If starting fluid caused it to sound flooded out, chances are that it was flooding out prior to the starting fluid. You may have a problem with the injectors or the fuel system in the throttle body (leaking FPR or o-rings).
andrewrj
May 6, 2012 07:28 PM
princered72
Sep 13, 2011 10:36 AM
Dark Rider
Aug 8, 2010 11:57 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
