2.8l or 4.3l
Old May 21, 2010 | 08:44 PM
sammyboi's Avatar
sammyboi is on a distinguished road
Exclamation 2.8l or 4.3l
my 86 blazer had a 2.8 in it should i swap it for a 4.3 or find another 2.8
Old May 21, 2010 | 08:52 PM
Going to a 4.3L means you'll have to find a different transmission as well. You can swap in a 3.4L v6 from a camaro/firebird as a direct swap for your 2.8L and get more cubes.
Old May 21, 2010 | 09:26 PM
sammyboi's Avatar
so a 3.4 would just be a thing of getting it and dropping it right in without having to modify the engine mounts or anything???
Old May 22, 2010 | 12:06 AM
84BlazerS10's Avatar
I think you would probably have to change engine mounts radiator and transmission.
Old May 22, 2010 | 11:46 AM
If you go to the 3.4L, it is a direct bolt in as I already said. Mounts are the same although, while you have it out, you may want to replace the mounts.
You will not have to mess with anything else.
If you go to the 4.3L, then mounts, transmission, etc will need to be changed.
Old May 22, 2010 | 06:05 PM
sammyboi's Avatar
ok thank you for helping me out
Old May 23, 2010 | 10:16 PM
neo71665's Avatar
3.4 is the way to go, its just like pulling a 305 out and putting a 350 in its place.
There was also a 3.1 in the f bodies that is also a direct swap.
Personally the 4.3s were only good to use as the base for a v8 swap. I've never like the engine design nor the problems that came with chopping the 2 cylinders off.
Old May 24, 2010 | 09:39 AM
sammyboi's Avatar
the reason why im putting a v6 in my blazer is beacause i got a 79 el camino which is gonna be the v8 car
if i was going to put the 4.3l in my blazer how would i get it so the mounts line up instead of modifying the frame
Last edited by swartlkk; May 24, 2010 at 10:25 PM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Old May 24, 2010 | 10:27 PM
The frame should not need modification. Simply use the 4.3L mounts from a newer 1st gen and you should be good to go concerning the mounts. But as stated, if you are thinking of going to a 4.3L, you might as well go v8 because the work is almost the same. The 3.4L v6 swap will net you a good gain in power and not require a host of other changes to make it work.
Old May 25, 2010 | 06:11 AM
sammyboi's Avatar
well if im gonna put a 305 in it what would i have to do cause its carburated and the truck had a throttle body engine in it
