2 door 98 blazer ls transmission
Old Dec 23, 2015 | 11:55 AM
Bejaran's Avatar
Bejaran is on a distinguished road
Default 2 door 98 blazer ls transmission
Hi I have a 98 blazer about 190k miles I bought it in February 2015 but I just recently started driving it because I didn't have my license. I replaced the battery I had to change the locks I put a new fuel pump fuel filter changed the oil and oil filter bought a new windshield and hood because the windshield was cracked and the hood was banged up I put shocks for the rear windshield I bought a new heater core since it didn't have one I replaced dashboard because it was cracked and broken I replaced the drivers window motor and regulator I have the passenger motor and regulator just haven't had time to put it on but my question is: Should I replace the transmission? My dad is a mechanic and has been all his life and he told me when the transmission has old fluid that has been there a long time it's not worth changing because then that's when you'll have problems
Old Dec 23, 2015 | 02:14 PM
newguy's Avatar
your dad is right. Dont do it. Basically the crud is keeping everything working. New fluid has a detergent in it and will clean the crud of off everything and it may start slipping. How do i know this? Changed my fluid three years ago and the tranny went 2 weeks later. slipping clutch pack plates
Old Dec 23, 2015 | 06:25 PM
Bejaran's Avatar
So should I replace the tranny all together or just leave it alone?
Old Dec 23, 2015 | 07:05 PM
newguy's Avatar
leave it alone if it works fine. If it aint broke, dont fix it
Old Dec 23, 2015 | 07:09 PM
Bejaran's Avatar
Okay I'm about to have a Borla muffler welded on because the one it came with has a hole
Old Dec 23, 2015 | 10:50 PM
Toocute350's Avatar
Toocute350 is on a distinguished road
Like newguy said"If it aint broke..Leave it along!"If you have the funds in doing a transmission replace..Go for it.But I`m sure with todays economy ,no one has money to blow .
hlaverty06
Mar 23, 2014 09:25 AM
ussexplorer
Aug 10, 2011 12:14 PM
ussexplorer
May 11, 2011 09:04 PM
MowJo
Aug 13, 2008 08:52 AM
dropd4door
Feb 10, 2006 02:34 PM
