2000 4.3 Blazer misfires and temp gauge drops
Old Aug 22, 2016 | 10:28 AM
oneluckymann's Avatar
oneluckymann is on a distinguished road
Default 2000 4.3 Blazer misfires and temp gauge drops
New, here on the forum. I have been living here in Costa Rica for 11 years now. Most mechanics do not know how to work on american cars, only Asian imports. With that being said,I have a 2000 Blazer LE with the 4.3 ltr. vortex engine. Here's the problem. If I visit the U.S. and let my car sit for a couple of weeks, when I come back and start the car, it runs fine for a day or 2. Then, this problem occurs. It starts to misfire, like one cylinder is missing. It bumps hard when idling. Also, the temp gauge goes crazy. Up and down to eventually all the way down. I replaced both o2 sensors and had the injectors cleans. I replaced the mass air flow sensor and then my mechanic sid the new one was bad so he put the old one back on. Still having problems. Any help would be greatly appreciated.
Old Aug 23, 2016 | 08:02 AM
LesMyer's Avatar
Does the temp gauge go crazy at the same time the engine starts to miss? Does the temp gauge behave itself all the time that the engine runs well? Is the SES light on? If so, what are the stored codes? If engine is missing there should be a misfire code stored at a minimum of "pending"
Old Aug 24, 2016 | 06:18 AM
newguy's Avatar
sounds like temp sensor to me
Old Aug 25, 2016 | 07:27 PM
The temp gauge goes crazy when it starts to misfire. Now if appears that not working at all. I will put it back on the computer and get a code next week.
Old Aug 25, 2016 | 07:28 PM
The temp sensor can make it misfire? Didn't know that, however, I'm not a mechanic. I really do appreciate the help.
Old Aug 25, 2016 | 08:18 PM
Would that be the intake temp. sensor, coolant temp sensor, air charge temp sensor or the ambient air temp sensor? Kinda confused here.
Old Aug 25, 2016 | 11:15 PM
newguy's Avatar
Coolant temp next to 3 plug. Had mine come unplugged and ran like crap and gauges all over the place
Old Aug 26, 2016 | 09:02 AM
LesMyer's Avatar
Also look at the coolant temp the PCM is seeing while you are at it.
Wincanton
Aug 7, 2015 07:13 AM
BlackBlazerCricket
Jun 4, 2014 12:40 PM
zakm0n
Jan 9, 2011 07:31 PM
RomanCatholic
Nov 9, 2009 06:14 PM
AEChevy
Jan 20, 2009 10:19 AM
