2000 blazer got wet now shifting wrong please help
ok i got a 2000 blazer 4 wheel drive 4 door i went through a creek and got stuck the car died so i had to get pulled out in nutral but the ar was in 4 lo got it out and got it running but the tccm (transfer case control module) got wet so it was stuck in four lo so i went to the junk yard and got a tccm and got it out of four lo and when back in 2wd drove down the rode and it would only shift into first and second gear is there a transmission control modual that could of got wet or anyhting i could really use the help thanks
*Thread Closed - Double Post* - Please do not double post as it is against forum rules. If you post in a particular section and later think you may want that post moved to a different section, please contact a member of the staff for some assistance.
BigEffingHammer
08-27-2014 01:39 PM
bmx4life218
08-03-2010 01:32 AM
91s-10blazer
09-01-2009 03:50 PM
