2000 blazer hard to start
Old Mar 20, 2012 | 06:04 AM
  #41
70Camaroman's Avatar
70Camaroman is on a distinguished road
awesome!!!
Old Mar 20, 2012 | 11:58 AM
  #42
siddhartha's Avatar
siddhartha is on a distinguished road
dude that is awesome!! yea i ended up ordering one from ebay and it fired right up also...yea sorry it took so long to get back at ya guys but car is back up and running.
Old Mar 20, 2012 | 12:10 PM
  #43
pettyfog's Avatar
That's great guys! Thanks for sharing.
Dunno exactly what it was, though.. I didnt learn anything.
Old Mar 21, 2012 | 08:41 AM
  #44
What Ebay seller did you acquire the pump from?
Old Mar 21, 2012 | 07:51 PM
  #45
pontiacguy's Avatar
pontiacguy is on a distinguished road
The name of the seller is aitc168
The item number is
AUTO-SUMTO 160655593213
Old Mar 22, 2012 | 09:58 AM
  #46
Thanks, Let us know if it dies. Good luck.
Old Mar 22, 2012 | 10:27 AM
  #47
pettyfog's Avatar
The item number is
Dunno what's so tough about copy-pasting url..
The guy's ebay store is Auto-Sumtown
http://stores.ebay.com/AUTO-SUMTOWN/...d=p4506.c0.m57
but here's the first fuel pump for ours I came across.
OLDSMOBILE BRAVADA 98 99 00 01 FUEL PUMP Brand New | eBay
And reading WAY down... here's the specs
GM # 25178729
PRESSURE: 3Bar
FLOW: 120L/h
3 bar... 45 psi. Hmmmm. No thanks.
It says on another source site 'Select a flow rating pressure above your operating pressure for best results'.
So that would be 5 bar. Doesnt mean any given pump for that rating wont last.. it just reflects likelyhood of early demise, all else equal.
Old Mar 22, 2012 | 01:19 PM
  #48
siddhartha's Avatar
its was a weak fuel pump haha. yea it mite of not been such a big learning op. but for me it was. id rather check everything before i replace a part. at least now i know all the steps to properly diagnose this problem and fix it. thanks for the help.
Old Mar 23, 2012 | 06:50 AM
  #49
pontiacguy's Avatar
Thanks for the lesson on the bar thing (actually I googled for the lesson). I guess that pump must be underrated by that standard, because we already know that these two trucks (at least) won't run on 45 or 43.5 psi or whatever. So somewhere the math is wrong. My $20 pump peaks at 61 to crank and regulates at 55. But if I had a fat wallet and cost was no object, I'd just take it to the dealer and not worry about such petty nonsense.
Old Mar 23, 2012 | 07:10 AM
  #50
pettyfog's Avatar
Let me say it again. That is a design/production test standard to which the pump is built. The point is all production must meet or surpass.
The absolute head pressure {return plugged} of one pump might be 100 lbs, the next.. 65 lbs. Either of those would probably pass 3 bar 120 lph.
Look at it like this: Your house wiring if it's built in last 60 years is power/ insulation rated to 600 volts. Do you think you should settle for a 200 volt rating?
12 ga wire can actually handle 30 amp easily, it's never to be fused for more than 20. Should you put a 30 amp breaker on it, anyway?
It would work fine.. almost all the time.
macblazer109
Sep 24, 2012 10:34 AM
netslinger727
Dec 30, 2010 08:32 PM
uncledenny
Oct 28, 2009 04:38 PM
bking_27
May 24, 2009 04:27 PM
fremontt
May 7, 2007 12:42 AM
