2000 Blazer Hesitaion
Old Dec 6, 2012 | 12:09 PM
pkwitt86's Avatar
pkwitt86 is on a distinguished road
Cool 2000 Blazer Hesitaion
I have a 2000 blazer that runs rough when you first start it up.It hesitates when warming up. When it warms up it runs great. I have changed out the fuel filter, air filter, spider injector, spark plugs, rotor, plug wires, distributor cap and coolant temp sensor. I have also cleaned the Egr and maf sensor and still no luck. I have also fixed the vacum leak. Does anyone have any ideas?
Old Dec 6, 2012 | 01:41 PM
mrspeedy69's Avatar
mrspeedy69 is an unknown quantity at this point
What brand of parts did you use? I've heard these things only like ac delco parts. What about your fuel pressure, and have you replaced your O2 sensors?
Old Dec 6, 2012 | 01:49 PM
pkwitt86's Avatar
I used napa parts and ac delco plugs. fuel pressure was 60 psi with key on and dropped to 52 psi after it was shut off for 15 minutes. I replaced one o2 sensor that was bad when i bought it. I forgot to mention its throwing a lean code.
Old Dec 6, 2012 | 04:36 PM
geo's Avatar
geo
geo is on a distinguished road
pressure seems low, you may want to test it at the fuel filter. Captain Hook replied very useful information in my post about how to test it.
My blazer seems fine now after changing fuel pump. It was starting rough around 300-400 rpm in the morning and sometimes won't start.
Old Dec 10, 2012 | 06:54 AM
pkwitt86's Avatar
On the way home on Friday it was running very rough and didn't want to move from a dead stop. I made it home shut the truck off and it wouldn't start back up. The pump makes no noise at all. What is a good pump brand to buy without breaking the bank?
Old Dec 10, 2012 | 10:01 AM
50lb_cat's Avatar
Stick with ac delco or delphi if you want it to last any amount of time.
jello219
Sep 3, 2019 05:19 PM
614blazer
Jan 16, 2012 03:34 PM
01Blaze218
Oct 13, 2011 10:05 AM
Blazerk9unit
Jul 25, 2010 11:53 PM
Suspension Plus
Dec 17, 2008 01:54 PM
