2000 blazer no spark
Old Dec 30, 2011 | 04:15 PM
capt nemo's Avatar
capt nemo is on a distinguished road
Default 2000 blazer no spark
Died driving down the road and has no spark at plug. Replaced cap, rotor, sensor mounted in distributor (crank?). Tested ig module and passed and coil ohms out the same as a new one. Have pulsing signal at one coil wire and 11.5 volts at other that drops to 10 something when cranking. No spark out of coil. Was going to try coil next. Any advise?
Steve
Old Feb 19, 2012 | 06:38 PM
70Camaroman's Avatar
70Camaroman is on a distinguished road
I see that you have the same problem as I am having with my 2000 Blazer. Did you ever figure it out? Seems as though you did not get any input from the forum.
Andy
Old Feb 20, 2012 | 09:02 AM
capt nemo's Avatar
Sorry for not replying to close this post. It ended up being the coil even though I could not detect any difference with an ohm meter between new and old. That is why I tried other things first but finally tried the coil and it fired right up. There are some older posts that that have different tests to do, I followed these tests and it pointed to the coil.
Good luck!
JavierEscalonJr
Oct 14, 2020 11:38 PM
blazzer
Jun 4, 2013 04:40 PM
abe_f
Apr 1, 2013 11:19 PM
Yankee Team1020
23
Aug 3, 2011 08:05 AM
jerickso
Apr 13, 2006 02:24 PM
