a/c compressor clutch - 2002 Blazer
Old Feb 19, 2012 | 02:33 PM
jrmst50's Avatar
jrmst50 is on a distinguished road
Default a/c compressor clutch - 2002 Blazer
Does anyone know how to change the clutch for the a/c compressor on a 2002 blazer? I rented the spanner wrench, but there doesn't appear to be a nut in the center of the clutch. It appears to be a round clip. How do I remove this round clip? I would greatly appreciate any advice. Thanks.
Old Feb 19, 2012 | 03:19 PM
pettyfog's Avatar
Later dont have a nut. It's pressed on, anyway.*
You remove it with a clip remover, looks sorta like pliers with pins attached, or carefully pry out with a thin blade screwdriver.
You dont really need that spanner until you install.
You need a clutch removal/installer puller set too.
search google and youtube, plenty of directions
* The reason the nut is redundant is that the clutch itself is pressed on to a certain clearance from the pulley.. about .025"
The nut being on the outside helps nothing there. When the clutch is engaged and compressor running it's held TO the pulley which is in turn captive of the above clip. When not engaged, it's not turning so there's no impetus for it to back away.
Old Feb 20, 2012 | 11:53 AM
jrmst50's Avatar
Thanks for your help. I'll have to get the puller for the face plate.
Thanks,
Jim
gmcjimmy_94
Dec 30, 2010 12:37 AM
BooTs
Jun 13, 2010 09:56 PM
gomfrddy
May 12, 2010 01:51 AM
Mroink
Aug 4, 2007 02:05 AM
NJEMT
Jun 1, 2006 01:40 AM
