2000 blazer no start.
Old Mar 27, 2017 | 10:14 PM
spades's Avatar
spades is on a distinguished road
Default 2000 blazer no start.
Had a fire due to o ring where gas lines going into spider. Pulled motor and trans. All new gasket and timing chain on motor. Pulled wiring harnes and checked continuity in EVERY wire going to every sensor ect. New parts include distributor, wires, plugs, crankshaft sensor, ecm, coil, module,knocksensor, spider injector,neutral safety switch, oil pressure switch.
I have no spark. It's got me second guessing the alignment of the timing chain and gears. Will that cause absolutely no spark?
Old Mar 27, 2017 | 10:55 PM
newguy's Avatar
That will not. Do you have power to the coil?
Old Mar 28, 2017 | 04:38 AM
spades's Avatar
no I traced it to the crankshaft sensor. Had voltage but when I turned the crank by hand and no switching voltage. Come to find out it wasn't seated flush so it wasn't picking relaying signal to ecm. By then it was to late to try and start truck.
When I put different ecm in blazer do I have to do passlock again. The reason I say again is I got stranded with key stuck in ignition. Long story short I put in switched push start and did passlock. Directions with new ecm said to do passlock but when I tried the security light never goes out. Solid not flashing.
coolasice
Dec 9, 2024 09:53 PM
01Blaze218
Oct 13, 2011 10:05 AM
RLELLIOTT
Aug 2, 2007 04:18 AM
fremontt
May 7, 2007 12:42 AM
westernbronco
Jan 23, 2007 02:16 PM
