2000 Chevy blazer pcv valve cover problems
Old Dec 7, 2018 | 01:31 PM
Megamatt's Avatar
Megamatt is on a distinguished road
Default 2000 Chevy blazer pcv valve cover problems
Ok so I have a 2000 Chevy blazer 4x4 4.3 that usually cranks hard but always starts it runs fine no problems other than when sometimes when I’m cranking the ignition my pcv valve cover blows off of the intake manifold it is not the pcv valve itself it is just a cover with a hose in it that comes from the pcv valve. It’s just a little plastic cover that you push down and twist and it locks in its got a line to the pcv valve and a vacuum line connected to it. I’ve replaced it ten times and I’m tired of doing it. It only blows and breaks off when cranking to start if anyone could know what is causing this and could lend some insight it would be appreciated thank you
Old Dec 8, 2018 | 03:11 PM
Following because I need to know what in the world would cause this!
When you say it "blows off" are you saying that there is some sort of high air pressure pushing it out? Could it be something like a throttle cable or some such thing that is pulling it out? Is the twist-lock mechanism not catching?
Old Dec 8, 2018 | 04:07 PM
odat's Avatar
Cranks hard - blows PVC cover off when cranking - sounds like your timing is off creating crank case back pressure - Via timing too far advanced
Old Dec 9, 2018 | 01:49 PM
Megamatt's Avatar
I think back pressure or something since it’s sucking and not blowing any air but the twist mechanism is like two little ears and they just break off with a poof of smoke from under the hood coming from the blown off cover
Megamatt's Avatar
I will check into that thank you sounds like a good start
Old Dec 9, 2018 | 01:52 PM
Megamatt's Avatar
could it be a bad crankshaft position sensor?
Old Dec 9, 2018 | 03:59 PM
Sounds like it's backfiring into the intake and pressurizing the vacuum hose.
Chlorin8ed
Mar 10, 2016 09:16 AM
marksoftball
Nov 29, 2014 09:27 PM
Robt77
Apr 25, 2014 07:29 PM
kancop
Feb 17, 2014 08:06 AM
BlazerSS
Feb 20, 2009 10:48 AM
