2000 chevy K3500 7.4 vortec running problems
Old Apr 1, 2021 | 10:29 PM
Wvman93's Avatar
Wvman93 is on a distinguished road
Default 2000 chevy K3500 7.4 vortec running problems
I have a 2000 chevy k3500 dually 4x4 it has an issue while running if u are parked idles fine rev it up it goes to 3 grand and start studdering when floored if u ease into it ir revs all the way up. While ur driving it it will run fine then all of a sudden it will start not reving and after a bit it will start running normal i change fuel pump and filter and plugs and wires and distributor cap and button converter were clogged i removed them and just put pipe to replace them only have o2 sensor only in front of cats has lean codes on bank 1 and noticed with live data o2 sensor on bank 1 work when it acts up it has no volts. Has a little leak at donut gasket gonna fix is there anything else that can be wrong
Old Apr 2, 2021 | 05:08 AM
Also check for vaccum leaks.
Old Apr 2, 2021 | 09:17 PM
Wvman93's Avatar
thanks ill definitely check it since i only have the two o2 sensor before cats do i have to put them back on?
Old Apr 4, 2021 | 09:18 PM
Wvman93's Avatar
​​​​​i checked for vacuum leaks dont have and and cleaned maf sensor would the o2 sensor cause that kind of problem
Wvman93's Avatar
88sam
May 21, 2019 07:52 PM
Mitsuman
Jan 25, 2018 09:06 PM
Royce Johns Schwienebart
Oct 4, 2016 07:48 AM
rob2129us
19
May 3, 2012 01:59 PM
johnsgarage1001
Mar 11, 2007 01:27 PM
