2001 4L60E in a 94?
Old Feb 25, 2019 | 10:23 AM
arick793's Avatar
arick793 is on a distinguished road
Default 2001 4L60E in a 94?
I'm looking at a 94 S10 Blazer that has a bad transmission, and I have a 2001 GMC Jimmy parts truck that has a good trans. Both trucks are 4.3 liter 4L60E 4x4's. Can I just put the newer trans in the older truck without any issues? Thanks in advance
Old Feb 25, 2019 | 03:09 PM
Transman304's Avatar
Won’t work. 94 hs on/off type lock up strategy the 2001 has a PWM type. Totally diffrent PCM needed to control. 94 is a one piece case the 2001 is a 2 piece case. Good luck.
Brad
Old Feb 27, 2019 | 07:31 AM
arick793's Avatar
Brad
I knew there had to be something different. Thanks man!
Old Feb 27, 2019 | 08:39 AM
No problem, good luck.
Also forgot to mention that the 2001 wil have a MLPS (neutral safety switch) on the outside of transmission and the 94 doesn’t use that.
Brad
94BlazerGirl
Aug 28, 2014 06:14 PM
hulk
Aug 28, 2010 08:57 PM
maximashift
Nov 17, 2009 09:33 AM
2001BlazrLS
Jul 16, 2009 02:24 PM
Hayden3918
Mar 2, 2009 01:27 PM
