-   -   2001 Blazer 4.3 Knock Sensors (https://blazerforum.com/forum/engine-transmission-35/2001-blazer-4-3-knock-sensors-14980/)
porta5 Dec 3, 2007 08:51 PM
I am having trouble finding the knock sensor/s on my 2001 4.3 blazer. The book says there are two of them under each cylinder bank. Trying to order a new motor from Jasper and they want to know whether my motor has screw in orbolt on sensors. Any ideas?
porta5 Dec 6, 2007 09:17 PM
RE: 2001 Blazer 4.3 Knock Sensors
Well, no one answered my call for help. In case anyone elso has this problem in the future, I found the knock sensor myself. It is located under the distributor cap against the fire wall. I had to remove the distributor to get to it and only saw it there by luck with a mirror and a flash light. It turned out to be a screw in type and not a bolt on. Good luck to whom ever needs this info in the future.
Chevy Lover Dec 7, 2007 01:44 AM
Glad you found it. Sorry I missed this post earlier.
[IMG]local://upfiles/2910/F2FA391A396A405582E1B8EC246FFD34.gif[/IMG]
Hanr3 Dec 7, 2007 11:11 AM
I finally got time to find it.
Yep back of the block and, yep, screw in type.
porta5 Dec 12, 2007 09:32 AM
Believe it or not we were all wrong. That is the picture of the sensor that chevylover posted and that is the sensor that Ihave on my engine. The problem is,GM calls that a bolt on sensor. When I ordered my engine from Jasper, I asked for a screw in and when it got here itiswhat looks like to me a screw in but in fact it is considered a bolt on. Aparently there are first generation motors and second generation motors. The one in my blazer is asecond generation (bolt on sensor) and the long block that I got is a first generation scew in type. This is the only difference.Now my problem is that I have to wait 2 more days for them to send me a new block and take this one back. Luckly I found thedifference just before setting it in the truck.Thedifference between the two sensors is thatone is a one wire sensor and the other is atwo wire sensor.My wire harness is a two wire. Is thereany way to convert to the one wire so I can press on with the engine swap. Possibly an adapter. I would rather wait for the new engine to arrive then either cut into my harness or replace the whole harness just for this sensor. Any suggestions!
bodhifirestarr Mar 17, 2009 07:02 PM
could I have a look at that picture,
swartlkk Mar 17, 2009 07:16 PM
Holy OLD thread...
Posted in other threads:
https://i11.photobucket.com/albums/a..._Locations.gif
bodhifirestarr Mar 17, 2009 07:22 PM
thank you, that certainly helps.
Outsydr Mar 17, 2009 08:43 PM
http://img3.imageshack.us/img3/715/deadthread.jpg
bodhifirestarr Mar 17, 2009 09:18 PM
What would the correct torque be for the knock sensor. I can't seem to find this out.
