2001 blazer 4.3l V6 vortex engine Po301 code
Old Sep 10, 2023 | 08:14 AM
Jpfanz1985's Avatar
Jpfanz1985 is on a distinguished road
Default P0301 code problem on a 2001 blazer
Hello Everybody! I currently Have a p 0301 code that has been constantly coming up. I have replaced multiple items on my 2001 chevy blazer 4.3L vortex engine and it still comes up.
Items replaced so far: Crankshaft position sensor, Spark plugs, Spark plug wires, Ignition coil, 4wd switch, Map sensor, Fuel injectors, Camshaft position sener with new Distributor.
vacuum lines are all good and the cylinder pressures are all within good running range from 125-130psi.
Next I was thinking to change the fuel filter but other than that I'm stumped what could cause the code besides maybe bad wiring somewhere. Any suggestions would be appreciated.
Thank you for reading and taking the time to answer
Justin Klein
Aug 19, 2020 09:34 PM
btbullrider
Sep 13, 2011 03:03 PM
dhicks128
Jan 3, 2011 12:40 PM
Bybsurfr32
16
Dec 19, 2010 05:02 PM
Bybsurfr32
Sep 16, 2009 07:19 PM
