2001 BLAZER in limp mode. Replaced both shift solenoids still doing the same thing
S10's with overdrive have a circle around the D icon on the instrument cluster. And of course you can feel it go into overdrive and the RPMs drop.
Diagnosis = AAMCO guy said 95% new (rebuilt) transmission with labor for $3300. I can get a rebuilt for $670 with a 3 year guarantee. I think I will start there and seek out the labor.
Did you happen to do anything else on your truck the day you changed your fluid? Specifically anything with/around the throttle body? The trans uses inputs from the Throttle Position Sensor and if the TPS got damaged/shorted/etc it can put the truck into limp mode.
Took it to a great mechanic. No codes. Could not really say the problem. Took it to AAMCO today. Did not initially understand that I had replaced the solenoids. Mechanic drove it around was able to manually get it in all 4 gears. Wanted to keep it overnight to pull the pan and look around, probably at the electrical. It was working fine until I replaced 3 quarts of fluid without a flush so I really don't know about the validity of coincidence of changing the fluid culminating in an electrical malfunction. When I did change the solenoids by dropping the pan I did not touch any electrical other than for the solenoids.
I was quoted 3200 to 3900 for a rebuild. I don't think so!
if you Google got all auto parts you can read reviews. The ones from the BBB aren't all that good. But they do a lot of business so you're going to get some gripes no matter what.
JEFF MADISON
GOT ALL AUTO PARTS &
A TRANSMISSIONS
989-891-9212
989-891-9293
100 S. River Rd.
Bay City MI 48708
JEFF MADISON
A TRANSMISSIONS
989-891-9212
989-891-9293
100 S. River Rd.
Bay City MI 48708
Was the wire down to the transmission or inside the transmission harness? There were no OBD codes. Aamco offered to drop the pan for $280 to be applied to the $3267 if I need a new transmission. I guess it would be money well-spent if it was just a wire but I certainly would not pay parts and labor for their rebuilt transmission.
