2001 Chevy Blazer LS 4.3L CA emissions chase
American, born and raised.......Valve job done, no vacuum line leaks, new (head) gaskets after 3 smoke tests no hint of smoke leaks anywhere. As before, engine runs very smooth, no hint of misses from idle through just before redline. This is my first California car and whole emissions thing, here, new to me. Layout of your engine bay different than mine. From above pictures, what did you circle in blue? Thanks again!
You mentioned a valve job, was any performance modifications done? either higher valve lift, ported heads/intake, or anything at all that would make it run differently, the PCM knows how a stock 4.3 should run and what it should see from its sensors, and if anything is done to make it run differently from stock, the PCM will pick it up and throw any number of codes, including the mystical P0300.
No modifications, but I bought the car "as is" with a chromed air intake, not stock. Cannot find a stock air intake anywhere, so far. I suspect that the previous owner may have tried to tune it at some time, just a hunch, though. I may go ahead with both the check valves, popped the P0440 code again today.
2001 Chevy Blazer LS 4.3L engine bay
. it has a 411 PCM??
thought those were a model year 2003 and forward thing.
You mentioned the previous owner may have tried to tune it, have any way of verifying it?
and lots of exposed wiring...
man model year changeovers are weird, dont make much sense either since GM didnt switch S10s to the new Serial bus until 2003+
I exposed the wiring because "rats" had eaten, a lot. This was painstaking, but, I had to find the shorts, exposed copper, etc. The ecu has been a question in my head, since I bought the car. I even ordered a new (refurbished) one, by a supposed reputable company, that ended up screwing me over. Anyway, stayed with the old one! Blazer starts just like it should, runs great and all. All finish work will be done when I get it through, smog!
this includes - Knock sensor, Cam sensor, and the crank sensor
Wiring still going over. I feel there may be a spot I didn't see or detect. This has been ongoing. It seems I've performed every detection procedure, My main focus has been wiring, from first seeing those eaten wires.
