2001 chevy blazer sputters and then stalled out as I had stopped
2001 chevy blazer
so I drove 26 miles fine. Then omw home from work my blazer starts to sputter, so I pull off the side of the highway and when I had come to a stop it stalled on me and will not start back up. It acts like it wants to start be wont..I also did not hear the fuel pump ingage. I gotta a new fuel pump otw. If this is not a pump problem please give me ideas to work please.
Welcome to the forum.
There are a number of possibilities for a crank no start condition, this article will explain how to approach it:
https://blazerforum.com/forum/2nd-ge...rticle-103750/
The best way to start is to see if it’s spark or fuel first since those are the two most likely. Do the fuel pressure test in the sticky and pull a couple of plug wires and check for spark. Let me know if you need any help with these. BTW, you should chose either an AC Delco or Delphi fuel pump if it needs to be replaced.
George
George
2001BlazrLS
Jul 16, 2009 02:24 PM
