2001 pcv problem
Old May 1, 2011 | 11:32 AM
mgutier's Avatar
mgutier is on a distinguished road
Default 2001 pcv problem
been having a problem for a while now with my 2001 4wd/4dr blazer where it was having an annoying grinding sound that turned out to be a bad rubber connector between the pcv and the metal tubes that connect it to the manifold (was dry rotted after 160,000). Eventually the problem turned into backfiring sometimes when i started it from the connection coming loose and sending the vacumn into a frenzy; I would push down on the pcv and restart the car and all would be well. So like I said I replaced that rubber part and all has been well but now the rubber stopper part that is on the manifold comes loose every now and then but I have no idea what to call it and cannot get a parts shop/chevy parts site to identify it...I actually have limited car knowledge and am only typing information based on what I have been alerted to by my dad. Anyone know the name of the part??? Thank you.
Old May 1, 2011 | 11:54 AM
rriddle3's Avatar
Sounds like you're describing the pcv manifold grommet.
Old May 1, 2011 | 12:26 PM
mgutier's Avatar
thats what i thought it would be called but none of the parts supplier pictures look like the part...ill post a pic later. thank you for the response
Old May 1, 2011 | 02:34 PM
rriddle3's Avatar
Originally Posted by mgutier
...ill post a pic later...
Yep, that would help.
jbsnowboarder16
May 6, 2011 11:48 PM
rob f
Dec 10, 2009 07:36 PM
Resolute
Dec 25, 2007 03:58 PM
4lowlife
Engine & Internal
Jun 28, 2006 10:35 PM
strongboy2005
Feb 17, 2006 04:44 PM
