General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Looking for the PCV
Old Feb 16, 2006 | 09:38 PM
strongboy2005's Avatar
strongboy2005 is an unknown quantity at this point
Default Looking for the PCV
Can't find it... I have a Chilton's auto book but I still don't see it... Help please...
(Trying to find it so i can put the seafoam in it)
Old Feb 16, 2006 | 09:42 PM
Default RE: Looking for the PCV
Should be on the drivers side valve cover. The PCV hose should be about 3/8" to 1/2" in outside diameter. You need to run the motor with the intake intact so that air flows through the MAF. I never tried it, but if you disconnect the MAF (unplug it), and try to start the motor, if it will run, you can pour the seafoam down into the throttle body.
Let me see if I can find an illustration showing the placement of the PCV valve.
Old Feb 16, 2006 | 09:44 PM
Here ya go:
[IMG]local://upfiles/667/23EB987C60A94A9D83B1E45C9306DBC7.gif[/IMG]
Old Feb 16, 2006 | 10:20 PM
Ok I couldn't find it but I was able to just pour it in the throttle body. It's outside right now "ventalating" before I take it on its hard drive, lol...
Old Feb 17, 2006 | 02:14 PM
Ok, I never could find the PCV valve, but I might be looking into replacing it today... Is it covered or just sticking out? Do I have to take anything off to get to it?
Old Feb 17, 2006 | 03:17 PM
Bocomo's Avatar
Bocomo is an unknown quantity at this point
You don't really need to take anything off. It is on the driver side valve cover. Probably a bit closer to the firewall end than the bumper end, but really it is close to the mid point of the valve cover. If you follow the air intake, where it passes over the valve cover that is just about where it is.
If check out swartlkk diagram post and enlarge it, it is number 8 on the diagram. It should have 90' bent hose coming up off the PCV.
I might be able to take a picture of it on Saturday and post it. Tonight I'll be a little busy.
Old Feb 17, 2006 | 04:44 PM
4lowlife's Avatar
It should be on the driverside valave cover. Don't replace it with Fram.
rob f
Dec 10, 2009 07:36 PM
tckocher
Apr 14, 2008 06:38 PM
Resolute
Dec 25, 2007 03:58 PM
blazinloud
Engine & Internal
Sep 14, 2006 12:08 AM
4lowlife
Engine & Internal
Jun 28, 2006 10:35 PM
