2002 4wd blazer has such an issue not revving above 1700rpm stalls if revved up?
Old Feb 4, 2023 | 01:56 PM
agentacer008's Avatar
agentacer008 is on a distinguished road
Thanks I will do that for sure I hear it too many times so it’s definitely gonna be a ac delco
Originally Posted by GeorgeLG
I know that they are more expensive but gat a Delphi or AC Delco pump. The failure rate of the off brands are just too high.
George
Old Mar 10, 2023 | 04:21 AM
Dayvid Doucette's Avatar
Dayvid Doucette is on a distinguished road
Default Got pressure finally
Finally got pressure after replacing the fuel pump. Just so forum knows. Anyways I was trying to find TDC now after aldo replacing distributor in this process, but I noticed my crankshaft pulley is bolted stationery but the harmonic balancer behind it for some reason is damaged and just spins freely, so using marks on engine wont work. My question is this, when you pull the crankshaft pulley off there is a notch in it that lines up with notch on crankshaft, is this notch at TDC on either stroke by chance? Is that notch a TDC indicator, if so will it be measured at same engibe marks for tdc?
Old Mar 10, 2023 | 04:27 AM
Default Tdc
With my balancer being damaged and useless in ginding this, once I find compression stroke on cylinder 1, how do I find the two marks needed to use to mark the exact middle of them being the true tdc. Like how do I find those measurements and being exact perfect tdc in my situation?
Old May 1, 2023 | 07:58 AM
Default Finally fixed
In the end I got a new distributor and spider and it fixed everything just for an update to all my blazer problems. I got both genuine AC Delco OEM parts for replacement.
Old May 1, 2023 | 08:56 AM
GeorgeLG's Avatar
Glad your fixed up
SnyderJ68
Jan 22, 2015 01:37 PM
zr2kore
Jul 31, 2010 03:21 PM
thir13en
Mar 31, 2010 08:33 AM
txblazin
Aug 31, 2009 01:31 AM
