2002 blazer
Old Jan 8, 2008 | 10:33 AM
gwaite's Avatar
gwaite is an unknown quantity at this point
Default 2002 blazer
Hi all,
I have a 2002 blazer with 78,668 miles on the engine, and this morning I noticed a slight pulling sensation towards the left when on the interstate going at about 65...
normally i would assume a tire, but this same issue also occurs when climbing... i'm not sure it's actually a pull (i suck at describing issues) all i really know is that at around 60-65 mph it feels like something is pulling slightly, which causes me to foot off the accelerator, and then re-apply to continue...
there are no censors turning on in the dash, car is running at less than 210 temp, which makes me think it's not the engine... but i have zero car knowledge, so i don't know.. hell, could it be bad gas?
any info is greatly appreciated!
Old Jan 8, 2008 | 10:50 AM
FFJustin99Chevy's Avatar
FFJustin99Chevy is an unknown quantity at this point
Default RE: 2002 blazer
Kinda sounds like you just need a front-end alignment
Old Jan 8, 2008 | 10:56 AM
gwaite's Avatar
that would be nice... i seem to be the "death touch" for automobiles, and i just bought this one in december and i really like it, so i don't want it to turn to crap soon..
i go over these massive speedbumps everyday, so maybe it's possible... thanks again
Old Jan 8, 2008 | 11:31 AM
Sounds to me like a tire, suspension, or alignment problem (or any combination of the above).
Old Jan 8, 2008 | 12:24 PM
rriddle3's Avatar
...and be sure to slow down before going over a speed bump.
Old Jan 8, 2008 | 01:38 PM
gwaite's Avatar
haha i crawl over these speed bumps, but the problem is... half of them were cut off and then they placed another speed bump on top of them, making the height of 2 speed bumps, and they were made very thin, so it's like you climb and then just suddenly fall.. the whole bit
Old Jan 8, 2008 | 08:06 PM
gwaite's Avatar
UPDATE:
Drove home from work today, still struggling to get over hills, and having a little trouble accelerating, not having trouble keeping speed once I hit like 60, but still experiencing a "pull" like sensation... kinda like when i accelerate it feels like im pulling back an elastic band, but i never get the feeling that it's going to snap back...
I'm still hoping it's an alignment deal... only worries me because my last vehicle (dodge stratus) experienced a similar issue that I spent over 1500 bucks on, before just buying a new vehicle. le sigh
Old Jan 8, 2008 | 11:23 PM
rriddle3's Avatar
Well now, this doesn't sound a thing like an alignment or suspension issue, but a powertrain problem instead.
Old Jan 9, 2008 | 09:12 AM
gwaite's Avatar
just noticed also, there appears to be a water leak occuring right behind the right front tire... i wasn't able to confirm this last night because the ground was wet from rain, but i noticed this morning that the lower left corner of the mudflap behind my right front tire was wet, and last night there was a stream of water going from that particular area... im getting ready to call the mechanic at the dealership i bought the vehicle from.. blah, i have the worst luck with automobiles...
Old Jan 9, 2008 | 10:11 AM
rriddle3's Avatar
If it's a stream of water from that area, it sounds like a leak from a heater hose. If it's just an accumulation it could be condensation from the compressor operation if you've been using the defroster.
