2002 won't get past 55 or so going uphill
Old Feb 23, 2009 | 03:47 PM
goodguy's Avatar
goodguy is an unknown quantity at this point
Default 2002 won't get past 55 or so going uphill
I have a 2002 4 door 2wd, v6... 90,000 miles... Just recently when going uphill and trying to get over 55 or so my blazer just has a hard time getting up over 55mph or so. I'll hit the accelorator and a rattling or pinging kind of sound comes out and my temp slowly climbs a bit. Not over 210 just about at that mark which is not normal for me... Otherwise runs fine, freeway flat driving I can get up to speeds I'm used to 65-80 and up.. I am missing some power getting there, and the noise is slight in this situation, but there...
I've heard anything from exhaust leak to push rods, to transmission, tobla bla bla... Any advice on what it could be. I'm going to get it looked at by my mechanic, but just to be sure I'd like to have an idea of what it is before hand... Any ideas?
thanks!
Old Feb 23, 2009 | 04:17 PM
rriddle3's Avatar
Default RE: 2002 won't get past 55 or so going uphill
If it's an early '02, I would say check the EGR valve to see if it needs cleaning. If it's a late '02 I would suspect the catalytic converter being plugged. Give it a good rap with a mallet and see if anything rattles.
Old Feb 23, 2009 | 04:25 PM
goodguy's Avatar
Ok, thank you... I was actually thinking that Cat might be an issue. I have on occasion hear a rattling type of sound coming from the Cat area while the car is warming up in the am on cold start. Does this make sense?
Also, once I rap on it with a mallet and if it rattles, what's my next step???
thank you so much!
Old Feb 23, 2009 | 04:27 PM
rriddle3's Avatar
If it rattles, replace the cat, and possibly the muffler if the insides of the cat have broken loose and migrated to the muffler, plugging it up.
Old Feb 23, 2009 | 04:29 PM
goodguy's Avatar
ORIGINAL: rriddle3
I see.. That's much better than what I feared... I'll check it out tonight and bring it in to my mechanic tomorrow... THANK YOU SIR!
Old Feb 23, 2009 | 05:34 PM
goodguy's Avatar
If the catalytic converter was plugged, wouldn't the check engine light be coming on? I have had no light come on during all this...
Old Feb 23, 2009 | 06:42 PM
rriddle3's Avatar
Not necessarily. There are also other possible causes of your problem such as plugged fuel filter, failing fuel pump, spark plugs and wires needing replacement, etc.
Old Feb 23, 2009 | 06:45 PM
goodguy's Avatar
Cool, thank you!
I just got a new fuel pump back about 30,000 miles ago at the most. This feels like a different problem all together than that was. But I have a place to start now... Thanks again, I'll be taking her in asap.
thanks
Old Feb 25, 2009 | 11:57 AM
goodguy's Avatar
FYI.. I needed a new Catalytic Converter and a Mass air flow sensor... Running like a champ now!
THanks allot!
Old Feb 25, 2009 | 02:33 PM
rriddle3's Avatar
Glad we were able to help a little.
