2003 Blazer tune up
Old 09-26-2007 | 01:25 PM
Default RE: 2003 Blazer tune up
You aren't replacing the entire distributor, just the cap and rotor. If you pull off the rotor and see debris on the terminals inside, then you need to replace the cap and rotor. Likewise if there is a crack in the cap. These are typical tune up parts on engines with distributors. If you remove the cap and find that it looks good underneith, then put it back on and return the parts. It really is up to you.
Old 09-26-2007 | 03:05 PM
cain_45's Avatar
cain_45 is an unknown quantity at this point
OOOO thank you for that information. I honestly didn't know. Duh!! So the only thing I need for a good tune up, the truck has 60K on it, is plugs, wires, cap, & rotor? I don't need anything else then correct?
This is awesome and by far the best info. I've gotten so far. I really appreciate it...thank you!
98blazin
07-14-2011 07:56 PM
iamfrugal
12-26-2008 09:28 PM
joshbea6
04-24-2007 02:47 AM
Blazerx85
04-11-2007 08:28 PM
BlazinBoats
07-12-2006 03:24 AM
