2004 check engine light and car shaking
Old Mar 30, 2012 | 03:26 PM
dlmallory's Avatar
dlmallory is on a distinguished road
Default 2004 check engine light and car shaking
I have a 2004 chevy blazer 2dr 4wd. Today when I started it up I noticed it was shaking some. I restarted it and it went away but on my 10 minute drive it started and the check engine light came on. I changed the oil wondering if it was that cause it was low and dirty but it didnt change anything. Also a fluid it being blown out the tail pipe. Smells like gas but not sure.
Has anyone had this problem or know a way to fix it?
Old Mar 30, 2012 | 04:05 PM
50lb_cat's Avatar
Did you get the code read? Most places auto parts stores will do it for free. Could be several things, get the code read and post back.
Old Mar 30, 2012 | 04:28 PM
dlmallory's Avatar
I got the codes read and it says the 3rd cylinder misfired. What has to be done to fix that?
Old Mar 30, 2012 | 04:54 PM
igs4dragon8's Avatar
igs4dragon8 is on a distinguished road
replace the spark plug for starers.
might fix it. worth the 3 bucks to find out
Old Mar 30, 2012 | 05:00 PM
dlmallory's Avatar
Yeah I think im gonna try that. Just trying to look to find which one is the third cylinder and where the spark plugs are exactly.
Old Mar 30, 2012 | 05:42 PM
rriddle3's Avatar
It's the middle cylider on the driver's side.
Old Mar 30, 2012 | 05:46 PM
dlmallory's Avatar
yeah just found that out. Tried to take the wire off but it wouldnt budge. Is there an easy way of getting to it and taking the plug out?
Old Mar 30, 2012 | 06:26 PM
rriddle3's Avatar
Use the 'search' feature for "number 3 plug" and you should get plenty of info.
Old Mar 30, 2012 | 07:21 PM
50lb_cat's Avatar
I agree sounds like a tune up is in order. I would do the wires,cap and rotor at the same time. The #3 plug is a PITA, I usually remove the air box and steering shaft and go in from the top. I would also clean the maf sensor while I was at it.
Old Mar 30, 2012 | 08:21 PM
dlmallory's Avatar
Should I replace all the spark plugs at once or is just replacing one for now fine?
Also where is that maf sensor located?
