2004 With Low Fuel Pressure
Old Feb 6, 2012 | 08:12 PM
gmoney6's Avatar
gmoney6 is on a distinguished road
Default 2004 With Low Fuel Pressure
I have replaced the Fuel Pump, Fuel Pressure Regulator, Spark Plugs, Mass Air Flow Sensor, and put in Fuel Injector Cleaner and my Blazer still bogs down when I press on the gas. Sometimes it doesn't get up to 3000 RPMs. Please with any suggestions!
Old Feb 6, 2012 | 08:13 PM
pettyfog's Avatar
Did you actually DO a fuel pressure test?
Did it set the Service Engine light?
Old Feb 6, 2012 | 08:51 PM
gmoney6's Avatar
The Service Engine Light has been on for a little over a year. The original code I got was P0101. Now I get P0102, P0171, & P0174 I believe... Low Bank 1 and Bank 2.
I have not test the fuel pressure, though.
Old Feb 7, 2012 | 03:12 PM
jck1961's Avatar
jck1961 is an unknown quantity at this point
P0102 is a MAF sensor code. P0171, P0174 are O2 sensor codes. I would try cleaning the MAF sensor and look for vacuum leaks.
Old Feb 7, 2012 | 04:24 PM
chris015's Avatar
you may not even have a fuel problem....
TEST THE PRESSURE with a fuel tester..autozone lends them out for free. just pay a refundable deposit.
Clean the maf with MAF cleaner...not brake or carb cleaner..
Old Feb 7, 2012 | 05:25 PM
xgiovannix12's Avatar
sign once again an other person guessing
heres a link on the fuel pressure diagnosis
96+ Fuel System Diagnosis - Blazer Forum - Chevy Blazer Forums
MTopper
Jul 12, 2011 12:19 AM
multiplicityz
Jun 17, 2010 07:21 PM
BlackOnBlack
Jun 24, 2008 11:52 PM
BorderDog
Jun 18, 2008 08:15 PM
scottyk
20
Mar 23, 2007 08:28 AM
