2005 Blazer 4 wheel drive switching problems
Old Dec 30, 2012 | 08:41 PM
jasondis's Avatar
jasondis is on a distinguished road
Default 2005 Blazer 4 wheel drive switching problems
It just started today,but when i switch from 2 wheel drive to 4hi or 4low i have a hard time getting back into 2 wheel drive.The light blinks and takes a few tries to get it back into 2 wheel drive. Any suggestion ?
Old Dec 30, 2012 | 09:57 PM
richphotos's Avatar
have you checked all the connections? make sure they are clean, especially at the transfer case, since that is exposed to the elements more so than the others.
also, check the DIY section of the board, to pull the codes from the tccm, see what it is telling you if there are any DTC stored.
Old Dec 30, 2012 | 10:09 PM
jasondis's Avatar
how many connections are there and where are they located ?
Old Dec 30, 2012 | 10:40 PM
richphotos's Avatar
I would honestly start at the one on the transfer case to clean it, but before you do that, check out this thread to read the DTC's and see if the tccm has stored any trouble codes, which could point to your problem.
https://blazerforum.com/forum/tech-a...ill-help-7180/
mirrorimij
Jun 8, 2019 03:34 PM
joejiz
65
Apr 15, 2014 07:58 PM
sunstaring
Dec 3, 2013 11:08 PM
lizzj70
Jun 23, 2010 06:57 PM
ninepointer
Jun 24, 2008 12:00 PM
