2200rpm at start, park and in neutral
Old Dec 28, 2014 | 05:16 PM
marcnet450's Avatar
marcnet450 is on a distinguished road
Default 2200rpm at start, park and in neutral
1995 Chevy Blazer vortex v-6 4.3l
Throttle valve is completely closed! Help.
Last edited by marcnet450; Dec 28, 2014 at 05:19 PM. Reason: Vehicle description added
Old Dec 28, 2014 | 06:21 PM
marcnet450's Avatar
*Is it possible by clearing the codes (unplugging battery) that the idle be reset to normal? At least temporarily? It's constantly at 2200rpm and the throttle valve is shut tight! ???
Old Dec 28, 2014 | 10:04 PM
hubert hefner's Avatar
hubert hefner is on a distinguished road
Have you checked it for codes? If so post them up so we can help you better.
It is possible for the TPS to cause this symptom.
Old Dec 29, 2014 | 06:01 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
If you have codes you need to tell us what they are. There are a couple of things besides the TPS that can cause this.
Old Jan 8, 2015 | 04:40 AM
marcnet450's Avatar
Found the problem guys! Some people, I have read (having the same symptoms), have changed the EGR, PCV, ICU, TPS, have done scans. . . spent tons of money before checking for an intake manifold leak. Yes, squirting a bottle of water around the intake revealed a leaky Plenum gasket just below the TPS. Now, to tackle that job.
donald.dtgray.gray4@gmail.com
Dec 18, 2020 07:31 PM
TireGrit
35
Feb 6, 2012 08:04 PM
bam_9_9_9
21
Apr 10, 2011 09:19 PM
mick.p.
Feb 7, 2010 01:53 PM
prnswitch
Feb 16, 2006 03:57 AM
