4.3 engine into suburban
Old Aug 22, 2010 | 02:26 PM
kickme005's Avatar
Banned
kickme005 is on a distinguished road
Default 4.3 engine into suburban
will a 4.3 engine fit into a Suburban? will putting 4.3 in, give my Suburban more miles per gallon? Also i got a 2.8 engine if i put that in my 95 Blazer how may miles will i get in 95 Blazer?
Old Aug 22, 2010 | 04:12 PM
rriddle3's Avatar
Old Aug 22, 2010 | 06:27 PM
g_mike's Avatar
g_mike is on a distinguished road
you could probably get it to fit if you took some parts from a silverado.
i see what you are getting at but no, you will probably get worse mpg.
the 4.3 is very underpowered and will have to work harder to get the suburban up to speed and to start off with on a good day it gets what...12-14mpg highway in the blazer?
here is the silverado that comes with both the 4.3L v6 and the 4.8l V8
compare the same drive line in both engines, the spec is within 1mpg rating.
in experience with the bigger vehicles, they tend to get better highway mpg with the bigger engines despite the rating.
http://fueleconomy.org/feg/bymodel/2...ilverado.shtml
i chose the silverado because it has both engine options factory so you can compare to what the suburban would get.
so for what mpg the blazer would get with the smaller engine, isnt that a stock engine size from the s10? look up the mpg the s10 gets with that engine.
Old Aug 22, 2010 | 06:50 PM
Blazer Steve's Avatar
Blazer Steve is on a distinguished road
Hi my dad had a full size chevy van with a 4.3.
Way under powered most hills where 2nd gear.
mileage on a flat road was ok but in the long run.
Keep your V8, tune it up. don't drive with a lead foot. That makes the most difference in mileage.
gmoney30
Nitrous, Super Chargers, & Turbos
Oct 25, 2010 12:50 AM
gmoney30
Jul 5, 2010 08:51 PM
Roudy4x4
Performance & Brainstorming
Feb 23, 2009 07:56 AM
EuroGoldLS
Detailing
Jun 5, 2007 01:07 AM
Garrett
Dec 28, 2006 04:14 AM
