4.3 innerchange
Old Jan 3, 2022 | 09:31 PM
flybird's Avatar
flybird is on a distinguished road
Unhappy 4.3 innerchange
Hey guys,
I have a 2001 blazer that the engine timing belt skipped and the engine itself was obviously tired. The rest of the blazer itself is in quite excellent condition so for me its worth dropping a new engine in. All the running gear has been recently serviced or repaired, the tranny has always been treated kindly.
Im told that only a 2001/2002 4.3 is directly inner changeable. I have access to a 4.3 2007 would there just be so much involved to install that its best to stick with the years the wrecking yards say are the only direct inner change?
Old Jan 3, 2022 | 10:44 PM
LesMyer's Avatar
Originally Posted by flybird
Hey guys,
2001 - 2004 Blazer only. Also, oil pans and sumps are different for 2WD vs 4WD. For 2003-4 in a 2001, you have to use the intake and exhaust manifolds from your 2001. Otherwise identical.
Later 4.3s have a different crank sensor/reluctor that makes them incompatible with a 2001 Blazer. Earlier than 2001 4.3s have a different knock sensor mounting hole in the block. If you can adapt the block to use the 2001 knock sensor, then 1996-2000 engines will also work.
orangewing
Aug 6, 2017 09:28 AM
A1 Handyy
Apr 7, 2015 08:28 AM
American Bulldog
Sep 30, 2011 03:00 PM
indigo
Jan 15, 2008 09:54 AM
BlaZinNaTe
Engine & Internal
Dec 29, 2005 05:38 AM
