4.3 swap info needed
Hi all. I just got a '94 S-10 Blazer with the 4.3 W code. It is bad. Today, I was given a 4.3 out of an 88 or 89 S-10 pickup. My question is, will this motor drop right into my blazer, or will I have to change anything on it. From what we checked on the motor in the Blazer now, it has a bad head gasket, and the 3 and 4 cylinders only have 80 psi of pressure in them. There is also a small knock in the motor. This is why I would just rather switch motors, cause the other motor I know is running fine. Eventually, when I get more money, I will rebuild the '94s motor to like new condition. But right now I just need something for winter. I need some suggestions, and some help if possible. I have been reading around here the past couple of days, and love this forum. The people here are very informative, and helpful. Thanks in advance!!!
Tim |
RE: 4.3 swap info needed
Hi and welcome to the forum! Have you read all my posts regarding knock and engine swapping? I've had great input by these guys (and moonwater :)) and hopefully you can use some (I realize they aren't the same) of the knowledge that was given in my situation. I for one am extremely impressed with the wealth of knowledge these guys have. And they aren't jerks "guarding secrets".
ORIGINAL: Talusgirl (and moonwater :)) |
I don't think it would be too much of a stretch to think that an 88-89 4.3L would work in a 94. One possibility would be that you may be able to use the older block... One problem that possibly could prohibit this swap is if your engine now has a balance shaft. You can swap out a balance shafted block with a non-balance shaft block (the 88-89 did not have a balance shaft). I'm unsure of other differences, but it doesn't look like there are major differences that would prohibit this. You would really have to get them both side by side to make sure that they would work. Things you need to check out are the accessory mounting holes in the heads & waterpump housing.
Thanks everyone for the replies!!! A little update: Today, I found out that the S-10 "donor", is a carburated '87 model. What I was thinking, is that we could take that block, and use the heads and intake system from my Blazer to make it work. I was reading somewhere, where you could go around the internal balancer, and things should work fine. Dont know if it will work or not, but worth a try. I'm new to working on Chevy trucks, as I used to work on import cars, not rice either, lol. Thanks again, and keep the responses coming!!!
Tim |
Moonwater, I didn't want to exclude you!:D
Back on topic... Anyway, I think that the only exterior difference between the 87 block and the 94 block may be ears for the transmission support bars... I'm not completely sure on that. Even if your block has a balance shaft, I don't think you will run into problems running with a donor block that does not. The only thing that you may notice is slightly more vibration from the donor engine. I do believe that all of your stuff from the 94 should bolt up to the 87 block, but you'd want to really compare all parts involved in the swap (ie. compare the 87 heads to the 94 heads including the water jacket holes and any bolt holes, etc). Good luck |
ORIGINAL: swartlkk Back on topic... Anyway, I think that the only exterior difference between the 87 block and the 94 block may be ears for the transmission support bars... I'm not completely sure on that. Even if your block has a balance shaft, I don't think you will run into problems running with a donor block that does not. The only thing that you may notice is slightly more vibration from the donor engine. I do believe that all of your stuff from the 94 should bolt up to the 87 block, but you'd want to really compare all parts involved in the swap (ie. compare the 87 heads to the 94 heads including the water jacket holes and any bolt holes, etc). Good luck As for a '87 carburated engine into a fuel injected engine. You will also have to swap water pumps, timing covers, and all the accessories. The multibelt setup will not work with the fuel injection serpintine set-up. All of that must be changed, unless you ant to run a carb'd engine. Then just scrap all teh fuel injection stuff, unless you have to pass emmisions. |
| All times are GMT -5. The time now is 11:18 PM. |
