4.3 tbi and 4.3 vortec question????
can i use a 1990 s10 blazer tbi block from a z engine and 1993 s10 blazer vortec heads and intake to make a w engine ? the w engine has a cracked block? so i have a engine that is a z code that came out of my 90 s10 blazer..
I believe you should be able to.
Have a read through this: Rebuilding The Chevy 262, Doug Anderson, Automotive Rebuilder, March 1998 |
I am curous about this too. But the years are a bit different. I want to use a '91 TBI 4.3 block & internals and a '96 Vortec 4.3 heads & intake. My concern is how the distributorless ignition system on the vortec will mate up. Any thoughts?
Both use a distributor. Neither are DIS.
The article liked to above should give some insight into this. Just look at the changes moving forward to the 95 model year. |
by my '96 is DIS, correct?
Originally Posted by Lower_Level
(Post 214036)
(Post 214036)
