4.3 tbi and 4.3 vortec question????
Old Apr 27, 2009 | 07:17 PM
deanosride's Avatar
deanosride is on a distinguished road
Question 4.3 tbi and 4.3 vortec question????
can i use a 1990 s10 blazer tbi block from a z engine and 1993 s10 blazer vortec heads and intake to make a w engine ? the w engine has a cracked block? so i have a engine that is a z code that came out of my 90 s10 blazer..
Old Apr 28, 2009 | 08:36 AM
I believe you should be able to.
Have a read through this:
Rebuilding The Chevy 262, Doug Anderson, Automotive Rebuilder, March 1998
Old May 1, 2009 | 02:18 PM
Lower_Level's Avatar
Lower_Level is an unknown quantity at this point
I am curous about this too. But the years are a bit different. I want to use a '91 TBI 4.3 block & internals and a '96 Vortec 4.3 heads & intake. My concern is how the distributorless ignition system on the vortec will mate up. Any thoughts?
Old May 1, 2009 | 02:46 PM
Both use a distributor. Neither are DIS.
The article liked to above should give some insight into this. Just look at the changes moving forward to the 95 model year.
Old May 1, 2009 | 02:53 PM
by my '96 is DIS, correct?
Old May 18, 2009 | 10:11 AM
PHATSPEED7x's Avatar
PHATSPEED7x is on a distinguished road
The 4.3L is the only V6 GM still used with a distributor. One of the best V6 in the history of mankind IMO. It's a SBC with two cylinders missing.
Old May 18, 2009 | 12:13 PM
No. It has a distributor as pointed out above.
deathman
Aug 14, 2011 11:25 PM
grimreper912003
Headers, Intake, & Exhaust
Oct 23, 2010 07:48 AM
maverik78
Performance & Brainstorming
Apr 11, 2010 10:05 PM
tony991
Engine & Internal
Jan 21, 2010 06:35 PM
ebornand
May 8, 2007 01:03 PM
