4.3 V6 Cylinder Misfires
Old Jun 19, 2013 | 12:54 AM
Tcannon408's Avatar
Tcannon408 is on a distinguished road
Default 4.3 V6 Cylinder Misfires
Hey, gang! I'm having an issue with my 2002 S-10 Blazer equipped with a 4.3L Vortec V6. It keeps throwing a code for a Cylinder 3 Misfire and sometimes a Random, Multi-Cylinder Misfire.
We have already replaced the cap, rotor button, plugs and wires, all AC-Delco. The #3 plug was checked since the code didn't go away, after doing the tune-up, to make sure it wasn't damaged while putting it in as it was in an awkward location.
I'm thinking this may be a distributor issue, simply because of the multi-cylinder code. Any thoughts? Thanks!
Old Jun 23, 2013 | 02:29 PM
Zach_99Blazer's Avatar
Zach_99Blazer is on a distinguished road
It wouldnt be a bad idea to replace upstream O2 sensors, a bad sensor on bank 1 was causing me to run rich and have misfires on 1,3 and 5
Old Jun 23, 2013 | 03:32 PM
Juggalo1003's Avatar
Juggalo1003 is on a distinguished road
It could also be the spider injection system as well causing a multiple cylinder misfire.
Old Jun 26, 2013 | 08:51 PM
Newblzrowner's Avatar
Newblzrowner is on a distinguished road
I had the same problem for about 6 months. Here is what fixed it: Cut the hole in the dist hold down bracket bigger and find out where it runs best. : No more misfire for me
Old Feb 3, 2014 | 03:19 PM
nomadjones's Avatar
nomadjones is on a distinguished road
Have trouble with # 3 and 5 cylinder also misfiring have it at garage now says it might be spider injector system i was wandering after reading this if the o2 sensor really controls it that much some said replace it is it worth a try
Old Feb 3, 2014 | 11:01 PM
erinvarghese's Avatar
erinvarghese is on a distinguished road
I had 2 Astro vans with the 4.3. (1995 and 1999) Had random misfires no one could figure out. Turned out to be simple, a worn distributor gear. Guess it was a common problem.
Old Feb 4, 2014 | 04:54 PM
Default O2 fixed mine
O2 sensor is worth a try. I had my neighborhood mechanic hook it up to his reader, and we could tell from the numbers that the 2 of the sensors were bad.
What happens with a bad sensor:
-exhaust mix leaving the engine shows bad fuel/oxygen content mix
-computer dumps in extra gas/oxygen into cylinders
-mix worsens, and bad mix either doesn't ignite or ignites poorly
definitely worth a shot if you can afford to put new sensors in. My blazer has 198k miles on it, and i didn't think it would ever run smoothly, but after 2 o2 sensors, she purrs like a kitten
Old Feb 5, 2014 | 09:28 AM
godzilla970's Avatar
godzilla970 is on a distinguished road
I had the same problem random misfires I bought a better cap and rotor at orileys auto parts that fixed my problem
Old Feb 8, 2014 | 02:36 AM
specialty8's Avatar
specialty8 is on a distinguished road
If all else fails do a compression test, it's free. That is where I found my culprit. Head gasket blown between two cylinders. Ran rough at idle but fairly well while driving it. Good luck.
Old Dec 26, 2020 | 05:02 PM
David Akin's Avatar
David Akin is on a distinguished road
its worth a try , hundred bucks a pop..
