4L60E 95 Blazer goes into lock up in 1st & 2 nd
Already rebuilt transmission. Now goes into lock up in 1st and 2nd gears. Will come out of lock up when I push on brakes. Will not go into lock up in third or four. Anyone seen this, or have any suggestions?
I have the same symtoms as you. Im wondering what it could be too. bad TCC switch maybe? or dirt in the screen?
I did the rebuild, did not replace pump. Found a crack in my filter after rebuild, replaced the filter. Still same problem. I should say it will not come out of lock up when I push brakes. Will not pull fluid out of pan until it warms up. Scanner indicates that I am pushing on brakes when I am not and says that I am not pushing on brakes when I am.
this link below is the cheapest price i found so far, let me know if you find it for cheaper, i need to get one too...
http://www.sjdiscounttools.com/atd-5550.html
monette999
Feb 1, 2011 08:23 AM
hotrodsbyg
Jul 3, 2010 02:37 PM
naf821
Aug 8, 2007 07:19 AM
blazerrick
14
Dec 28, 2005 09:07 PM
