4l60E low line pressure
Old Jan 21, 2016 | 07:35 PM
cos98blazer's Avatar
cos98blazer is on a distinguished road
Default 4l60E low line pressure
Hello,
I bought a 98 blazer a few months ago, with a bad transmission. Would not shift to third, would just skip to neutral. I did a complete rebuild on this thing, finding some very burnt 3-4 clutches, and replaced the input drum as it was flaking off aluminum, I guess from the heat. Also replaced all internal electronics - solenoids, PCM, even the wiring harness. and installed a trans cooler as well.
Re-installed the trans, and connected up a line pressure guage to the test port, after reading about line pressure issues. Sure enough the pressure was really low - 60 psi in P,N,D,3,2,1, and 80 in R. After more reading, found a suggestion to disconnect the big green connector to the trans, and when I did that, pressure was good - 160 psi in P,N,D, and 260 psi in R.
So my question is - does this mean the computer is bad? Or should I try that PCM ground fix? Line pressure does not fluctuate when the wiring is plugged in, just steady and low.
Thanks!
Old Jan 22, 2016 | 10:47 AM
A little more info, for what its worth - prior to pulling the connector, had a scanner hooked up to it, and no codes found. After pulling the connector and running thru the gears (on jack stands), it did throw several trans related ones - P0740, P1860, and one other. Then when connector re-connected, and codes erased, no new ones were thrown.
Old Apr 28, 2025 | 06:50 PM
trent's Avatar
trent is on a distinguished road
Default Help
Did you figure it out. I’ve had the exact same symptoms 1998 Silverado 4x4 loses 4th clutch’s. Low line pressure.
Old May 4, 2025 | 07:33 AM
Wow long time ago. So in my case, it was because I was checking the line pressure with the wheels in the air. You have to check it with the wheels on the ground, with a load. So when I put it down and drove it around, the line pressures looked good, and the trans shifted fine thru all gears
Stovey
Jul 10, 2024 08:06 PM
rmitch
Jul 2, 2011 02:02 PM
cardude59
Aug 22, 2010 11:08 PM
justin1795
16
Apr 25, 2009 09:25 AM
fnirish
Mar 18, 2007 02:05 PM
