4l60e no 1st and 4th
Old Jun 8, 2021 | 12:00 PM
Danizanon's Avatar
Danizanon is on a distinguished road
Default 4l60e no 1st and 4th
My 4l60e is not holding 1st and it doesn't engage 4th.. I changed both 12 23 solenoids and still the same problem... I adapted this tranny with a e-transcontrol PCM.
After changing both... I realized that when the car is cold it works first but after a little time running it stops... Actually it looks like it engages 1st but after a little movement it changes to 2nd.
My next thought maybe could be the pcw... Because when the oil gets warm the pressure decreases... But 2 to 3 is changing correct.
Any idea what I'm dealing with??
Old Jun 9, 2021 | 06:19 AM
Transman304's Avatar
Welcome to the forum! could you give a little more information on the controller and when the issue started? Any codes present, fluid level, and condition ok?
Brad
Old Jun 9, 2021 | 08:15 AM
Danizanon's Avatar
Brad
Thanks
E-Trans Control
This is the controller... I don't have the codes as I have it on a antique.. Fluid level is OK.. Actually this tranny was recently rebuild and used a TCI shift kit... And then it was put in the project... At some period of tests it was OK... But a fill days ago it started failing.. When is very cold the car its OK... But after a fill minutes it starts with no 1st and 4th... It was why I supposed it could be ta A solenoid... Change both... No luck... Maybe could be the PCS because I Have a very smooth changing from 2 to 3rd... My controller I can change the line pressure, before the problem I could change the value and have some hard shifting and now I can change the value and nothing.
Old Jun 10, 2021 | 08:54 AM
What year 4L60E are you using? Was this just a plug and play controller or did you wire it in?
Brad
Old Jun 10, 2021 | 09:40 AM
Danizanon's Avatar
Brad
It's a 96 and it's plug and play.. But I rechecked all wires and they are OK...
Old Jun 12, 2021 | 07:33 AM
A would you have the instructions for the shift kit by chance? Very strange behavior I would suspect electrical issue but very well could be mechanical. Have you contacted the controller company?
Brad
Old Jun 12, 2021 | 09:21 AM
Danizanon's Avatar
Brad
We just made a vacuum test on the VB and looks like we have a likeage on the 3 2 valve.. Do you think this could be the issue?
jezy
Feb 19, 2016 07:11 AM
Kocapuff
Jan 17, 2014 10:18 PM
flyhunter3825
Apr 1, 2012 02:44 PM
mychevyisntheavy
Aug 6, 2011 06:09 PM
Blazer1305
Engine & Internal
Dec 4, 2005 09:52 PM
