4l60e question
Old Jan 15, 2012 | 03:14 PM
richphotos's Avatar
Default 4l60e question
Ok, So I live in Minnesota, and when the temp is below 15 degrees and the Jimmy has been sitting over night, if I do not have time to let the truck warm up first thing in the morning, and I start to drive, the RPM's get pretty high before it shifts into 2nd, once it initially gets into 2nd, everything is fine and back to normal (meaning, I can stop at a stop sign, or a stop light, start driving and it flawlessly shifts through the gears, to the point where i can barely feel it.
And any point through the day when the truck is started, it shifts flawlessly. It is just on super cold mornings when I do not let it warm up for like 5-10 minutes.
Am I right to assume that it is just because it is cold? I checked the fluid, the level is good, the fluid is fairly clean, does not smell burnt.
Old Jan 15, 2012 | 03:33 PM
Irocz327's Avatar
Irocz327 will become famous soon enough
the fluid in your trans isn't warming up soon enought that might be your issue is a lack of preassure might be your issue.
Old Jan 15, 2012 | 03:40 PM
richphotos's Avatar
Thanks, That is what I was thinking.
I keep it parked outside, I have only noticed it really do it 2 times, and those 2 times the temp was between 8-10° with the windchill around -4°
Old Jan 16, 2012 | 02:02 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
I may be incorrect about this but I believe that when your transmission is cold the computer commands it to slip a little bit to help warm up the fluid. My '94 Blazer does the same thing.
Old Jan 16, 2012 | 06:30 AM
richphotos's Avatar
I read that while searching up the 4l60e as well.
Thanks for the response!
Old Jan 17, 2012 | 01:15 AM
You're very welcome. I replaced the 4L60E in my wife's '93 Jimmy last year and I learned a LOT about them.
dj00140
22
Nov 4, 2015 05:03 AM
an240172
Sep 7, 2009 02:58 AM
zrebmun
Mar 17, 2008 06:15 AM
95blazer8620
Oct 19, 2007 01:26 PM
chianesi
Jan 20, 2006 12:59 PM
