4L60E Tranny
Old Jan 31, 2008 | 08:22 PM
AtreyuManiac's Avatar
AtreyuManiac is an unknown quantity at this point
Default 4L60E Tranny
What vehicles can i pull this from?
If i have a 4x4 im looking to put it in do i have to pull it from another 4x4 or would i just bypass the transfer case?
I have a 94 s10 blazer 4x4 im looking to put it in.
Old Jan 31, 2008 | 08:30 PM
Default RE: 4L60E Tranny
You will need one from a 4x4 application if you want to use 4wd... You are going to be looking at any 4x4 S-series and 1/2Ton fullsize pickup You need one with a one peice case. Sometime in '96 they switched to a two piece case. So you are looking for a '93-'95 4wd transmission.
Old Jan 31, 2008 | 08:46 PM
Ok but can i only get it out of blazers/bravadas amd chevy gmc 1/2 tons from 93-95?
Or are there other car models i can get it from too
Old Jan 31, 2008 | 08:51 PM
If you are dead set on scrapping the 4wd system, you can open that up to any 4L60E from a number of different RWD sources. But then you would need to get a different rear driveshaft...
You should stick with replacing what is in there. Any '93-'95 4wd s-series or 4wd 1/2 ton fullsize donor will fit appropriately.
Old Feb 5, 2008 | 10:14 PM
Hanr3's Avatar
look for a thead in the Self Help section on the tranny removal.
dj00140
22
Nov 4, 2015 05:03 AM
an240172
Sep 7, 2009 02:58 AM
Hanr3
15
Jan 15, 2009 01:09 PM
95blazer8620
Oct 19, 2007 01:26 PM
