4l60e tranny issue?
Old Jul 27, 2017 | 06:49 PM
Paul Louis's Avatar
Paul Louis is on a distinguished road
Default 4l60e tranny issue?
so i had a rebuild done about a year ago. they actually installed a different 4l60e instead of rebuilding the old one which was pretty much beyond rebuild they said. anyway, since i got it back when i put the vehicle in drive, almost immediately, it sounds like the truck wants to just shutter and die but goes on and off like that till about 25-30mph. they said its an engine problem so i took it to them and they replaced mass airflow sensor, worked for a day then back to same experience in drive. The only way i can shift is manually. note I also replaced shift solenoids in valve body and still no worky. thanks in advance for help
Old Jul 27, 2017 | 07:11 PM
Transman304's Avatar
Vehicle info?
Old Jul 27, 2017 | 07:14 PM
Paul Louis's Avatar
sorry 2000 blazer 4.3. i am having an issue with black ground wire from fuel pump that keeps shorting out too. traced that to a splice pack behind fuel tank. any other suggestions?
Old Jul 27, 2017 | 07:52 PM
Check engine light on? Any codes?
First thing that pops into my mind is a faulty TPS. The computer adjusts a lot based off it's reading, from fuel delivery and ignition to transmission shift points.
MUDTRUCKMAN
Mar 15, 2017 09:45 PM
dj00140
22
Nov 4, 2015 05:03 AM
an240172
Sep 7, 2009 02:58 AM
Hanr3
15
Jan 15, 2009 01:09 PM
95blazer8620
Oct 19, 2007 01:26 PM
