4L60E trans help
I have a2000 2wd 4 door blazer that i need to get the trans out of . i have every thing done but the 3 bolts in the flywheel out . so how do you get them out and how would you get them back in after rebuild? i cant get my fingers to them to put the in or get them out . what is the trick here? thank for all your help in the past and on this .
got the trans out friday and rebuild today the pan had very lil metal flakes in it small then glitter. and some slug that looked like wet ground up pencil lead. all the stuff looked good inside but the sun shell.i got a new one and a new sun gear with then new large bushing but it wouldnt go on all the way.i had to use the old gear. so i need to know if in the use of this trans does the sun gear ever come out of the sun shell. if so i am screwed.
Sun gear is the one that goes into the bottom of the shell and has the snap-ring on it correct? If that is the one you are talking about, I've had that be tight before. I put them together with a rubber mallet. I'm VERY sure they do not move independant of eachother(if they do you have bigger problems). But if your gear was in good shape you can reuse the old one.
dj00140
22
Nov 4, 2015 05:03 AM
an240172
Sep 7, 2009 02:58 AM
95blazer8620
Oct 19, 2007 01:26 PM
