4L60E trans help
Old Jun 1, 2011 | 06:00 AM
garryb's Avatar
garryb is on a distinguished road
Default 4L60E trans help
I have a2000 2wd 4 door blazer that i need to get the trans out of . i have every thing done but the 3 bolts in the flywheel out . so how do you get them out and how would you get them back in after rebuild? i cant get my fingers to them to put the in or get them out . what is the trick here? thank for all your help in the past and on this .
Old Jun 1, 2011 | 05:50 PM
TZFBird's Avatar
TZFBird is on a distinguished road
If you havn't already, pull the starter and use that area to access the bolts. I use a breaker bar on the bolts with one hand and a large screwdriver or prybar to hold the flexplate from turning with the other.
Old Jun 2, 2011 | 06:03 AM
garryb's Avatar
thank man i didnt thank of that. will try it to day i know i can fit my fat fingers in that hole.hahahaha
Old Jun 4, 2011 | 07:38 PM
garryb's Avatar
got the trans out friday and rebuild today the pan had very lil metal flakes in it small then glitter. and some slug that looked like wet ground up pencil lead. all the stuff looked good inside but the sun shell.i got a new one and a new sun gear with then new large bushing but it wouldnt go on all the way.i had to use the old gear. so i need to know if in the use of this trans does the sun gear ever come out of the sun shell. if so i am screwed.
Old Jun 5, 2011 | 11:40 AM
chris015's Avatar
I believe it does.
Old Jun 5, 2011 | 03:03 PM
TZFBird's Avatar
Sun gear is the one that goes into the bottom of the shell and has the snap-ring on it correct? If that is the one you are talking about, I've had that be tight before. I put them together with a rubber mallet. I'm VERY sure they do not move independant of eachother(if they do you have bigger problems). But if your gear was in good shape you can reuse the old one.
dj00140
22
Nov 4, 2015 05:03 AM
fox440
Jan 9, 2012 03:37 PM
grounded87
Mar 25, 2011 06:36 PM
an240172
Sep 7, 2009 02:58 AM
95blazer8620
Oct 19, 2007 01:26 PM
