4L60E trans problem
Old Dec 18, 2011 | 05:27 PM
nordicroth's Avatar
nordicroth is on a distinguished road
Default 4L60E trans problem
Transmissionmission acts like it's in Over Drive in neutral, car is locked stationary in Reverse, engine feels loaded in ark,, all four forward positions work fine
Old Dec 19, 2011 | 06:53 PM
TZFBird's Avatar
TZFBird is on a distinguished road
I'm not sure what you're saying but it reads as though the shifter/indicator does not read what gear selection the transmission is actually in.
Try searching for the procedure to adjust the shift linkage. It's on here somewhere. If that does not work you can always replace the cable in case it has stretched or broke. Either way an adjustment should be performed.
Old Dec 21, 2011 | 01:32 AM
rpeastep's Avatar
rpeastep is on a distinguished road
I have had the nut holding the bracket on the transmission come loose and cause the same sort of problem, or at least sounds like what you are having. Might check that to make sure it is on correctly and tight.
Old Dec 23, 2011 | 02:49 AM
younger1993's Avatar
younger1993 is on a distinguished road
I am having the SAME EXACT problem right now with my '94....I just did a flex plate install and its doing this! did you fix it?
dj00140
22
Nov 4, 2015 05:03 AM
mychevyisntheavy
Oct 22, 2011 02:03 PM
an240172
Sep 7, 2009 02:58 AM
erobe387
Apr 27, 2008 06:12 PM
95blazer8620
Oct 19, 2007 01:26 PM
