4Low wont select
Gday people...My 99 LS Blazer wont select 4low..
Auto 4x4 & 4Hi work as normal but it just wont select 4Low.
Any advice is much appreciated..Cheers from Down Under
Try this stuff and get back to us.
Cheers Lesmyer :-) i tryed pushin the 4Low button with the car in neutral & rolling slowly as you said & it selected straight away
was a loudish clunk from under the front as it selected the first time but hasnt done it again...Thanks heaps for the advice
Glad it worked for you. I had read that out of my owners manual the first time I tried 4lo. I don't have much use for 4-lo, but I wanted to make sure it worked when I bought the vehicle.
Rolling was in my 2001 operator's manual if I remember correctly. I'll see if I can find it this afternoon as I have to travel between buildings anyway.
http://cdn.dealereprocess.com/cdn/se...001-blazer.pdf
See sections 2-32 and 2-33 - preferred method is rolling 1-2 mph in neutral, but stopped in neutral is also mentioned.
yeh same here...i dont use 4Low very much but have only just bought the car & wanted to be sure it all worked. unfortunatly i didnt get the owners manual with the car so have to try things as i go & ask questions...being in Australia doesnt make things easy either. Like trying to get a lift kit for it, i contacted Rough Country about their kits but they wont ship to Australia.
I believe Summit will ship to Australia. Here's a couple of kits made by Superlift.
Are the lift kits legal in your State? Might want to check regulations before going to the expense and work.
https://www.summitracing.com/int/par...t/model/blazer
p.s. I've been to Melbourne/Sydney/Brisbane on business back in 2003 but never been to the West side.
mmmm the 6in lift looks interesting but yeh i know they probly wont be legal down here...the 2.5in lift they will be kool with legally.
Cheers for the links Lesmyer
ive just sent an email to
summit regarding it....Thanks Again
& if youve never been to the West side, your missin out :-P we have some of the best beachs in the world....our coastline is truely spectacular
ive just sent an email to summit regarding it....Thanks Again
