4wd 96 blazer oil pan problems
Old May 1, 2011 | 07:30 PM
vanisher91's Avatar
vanisher91 is on a distinguished road
Default 4wd 96 blazer oil pan problems
im trying to remove the oil pan to replace to oil pump and clean the pick up screen i already have to axle pushed forward and the pan from what i can tell unbolted but it just wont drop it moves in every direction but no matter what i try it just wont come down it has more then enough room to drop but it just wont i tried lightly tapping it with a block of wood and a hammer i have the bolts removed where it connects to the block and transmission are there any more im missing?
Old May 3, 2011 | 01:54 AM
myprixxx's Avatar
myprixxx is on a distinguished road
did you get the two nuts near the front of the tranny and at the back of the pan? mine was super loose but just would not come off until we lifted the motor
Old May 4, 2011 | 08:33 AM
vanisher91's Avatar
Yeah I got thoese out without a problem I think it might be the oil lines that run right by it I haven't been able to work on it these past two days cause of the rain but tomorrow im going to try some other things on it why did they make it out of aluminum you can't pry on it
Bluebeastblazer57
Aug 11, 2012 11:05 PM
mierze
Jul 3, 2011 08:29 PM
AaronGene02
Jan 24, 2010 11:38 AM
biniecki
Nov 6, 2009 03:05 PM
Duckboat
May 29, 2009 10:17 AM
