4wd clicking but not engaging..
Old Feb 8, 2012 | 08:03 PM
97Beater4WD's Avatar
97Beater4WD is an unknown quantity at this point
Default 4wd clicking but not engaging..
Hey all
Having a problem with my 4wd...I'm thinking the actuator went (hoping its not more serious).
If I have my window down and hit the 4hi or 4lo button..I can't hear a click like the 4wd engaged BUT if I try to pull ahead in some mud or really wet grass on an embankment the front tires don't do a thing and the back tires just spin? Any suggestions? I had a similar problem in my zr2.. My battery leaked onto my 4wd actuator and it did the same thing... So before I replace the actuator...any suggestions?
Old Feb 8, 2012 | 08:22 PM
chevyblazer9588's Avatar
chevyblazer9588 is on a distinguished road
Check your vacuum line going to the actuator. My '95 vacuum line going to the actuator was burned off.
Old Feb 8, 2012 | 08:26 PM
Will do sir...I'm planning on bedlining my rockers tonight so that will gimme something to do while I wait for it to dry
Is it worth doing a manual cable mod?
Old Feb 8, 2012 | 11:24 PM
wheninromeSDS's Avatar
wheninromeSDS is on a distinguished road
There's like 10 vacuum lines. I'd take the battery out, then check that vacuum line, then get under the truck and go to the transfer case and check the lines running out of that. Keeps you from having to pull the lines out tocheck 'em, and mine were toast down there. Just a thought
Good luck!
seriosbrad
Nov 7, 2015 09:08 PM
Johnny Glenn
Feb 19, 2011 10:20 PM
Blazinflaboy
Jun 22, 2010 09:03 PM
rhs856
Jan 10, 2010 03:04 AM
chrisblaze
Dec 6, 2009 12:27 AM
